Re: motorproblem (Allgemein)
Andreas, Wednesday, 14.02.2001, 12:40 (vor 8462 Tagen) @ Karl
Als Antwort auf: motorproblem von Karl am 14. Februar 2001 10:15:13:
I have a 528i from 1985.I drove 30.000 km without problems and now i have a big
problem.It started a few weeks ago.Sometimes at the rpm is falling down and i
have to go from 3 gear to 2 gear.My radio is also going out.After going down
in gear the problem was gone.
The radio went off at the same moment when the motor problem occured?
Maybe then you have a problem with the connection from battery-minus to the mass of the car. There is a thick unisolated cable which sometimes breaks loose by vibration.
Andreas
BTW your link doesn´t work
