<title>E28-Forum - soundsystem problems...Part number 2 (english)</title>
<title>soundsystem problems...Part number 2 (english)</title>
<content:encoded><![CDATA[<p>Hello!<br />
 After the first part of the saga, i received a lot of info and sugestions from You. And I'd like to thank you. But the problem is still there.<br />
I give 1 answer to Nico, that seems to have a lot of experence with this stuff.<br />
I wrote  below what he asked me (I WRITE IN CAPITAL LETTERS , SO YOU UNDERSTAND WHAT IS MY ANSWER)<br />
O.K., so we have:</p>
<p>1.) Your radio is o.k. (SERVICED RECENTLY FROM BECKER OF MUNICH, THANK S TO MY FRIEND WHO HAS  HIS MUM LIVING THERE)<br />
2.) the sound system amplifier is also o.k., at least it seems so.<br />
IT SEEMS GOOD,OTHERWISE I PURCHASED 2 BAD AMPLIFIER ON EBAY...CAN I TEST THE AMPLIFIER IN SOME WAY? I TRIED THE LAST ONE IN THE CAR OF MY FRIEND , A 1985 M635 CSI, AND WORKED GOOD).<br />
3.) your speakers are o.k. (YESSSSSSS...)</p>
<p>But all together makes problems. (YEP.... <img src="http://e28-forum.lewonze.de/forum/images/smilies/frown.png" alt=":-(" />  )</p>
<p>What about the wiring? If you took the ampifier from a 86 E28, you should<br />
have that one below with only one rectangular connector.<br />
YES RECTANGULAR CONNECTOR<br />
(Do you use the wiring from the 528i?)<br />
WIRING LOOM WAS TAKENFROM A E30...WITH THE RIGHT WAY UNDER THE FLOOR, WIRES ARE LONG ENOUGH...HUH, THEY WERE NEW, SO I BELEIVE IT'S IN GOOD CONDITIONS)</p>
<p>and at pin 18 it should have a brown-black wire. <br />
As I put the sound system in my E28, I experienced that this wire must have<br />
gound (*NOT* the &quot;-&quot; of the speakers plug at the radio...!), or the <br />
amplifier makes strange noise. <br />
I TRIED TO PUT A JUMPER WIRE FROM THE PIN 18 TO THE GROUND ...IT MAKES NOT DIFFERENCE <br />
It does not really matter if your radio outputs 20 or 25 Watts. <br />
I WAS TOLD THAT A RADIO  WITH LESS POWER ENABLE THE AMPLIFIER TO MAKE LESS DISTORSIONS OF THE SOUND....<br />
Maybe you<br />
can roast your amplifier or or speakers, if you drive your system with<br />
full volume over some time, but you will be deaf than anyway.</p>
<p>Your power antenna should have a separate ground. IIRC the ground for<br />
this amplifier is below the back seat.<br />
I TRIED THE GROUND AND IT'S GOOD......BUT I HAVE OTHER BROWN WIRES IN THAT GROUND CONNECTIONS...MAYBE I HAVE TO TRY TO BOLT GROUND ON A &quot;EXCLUSIVE &quot; GROUND POINT).</p>
<p>THE ANTENNA IS A BOSCH AUTOJET 2 , IN WORKING ORDER....I DON'T THINK IT IS THE CULPRIT BUT I CAN TRY WITH A HIRSCHMANN AUTA 6000 . I BOUGHT IT FROM EBAY(LIKE NEW) , WHEN IT ARRIVES AT HOME i CAN CHANGE IT AND CHECK IT FOR THIS PROBLEM.</p>
<p>FOR EVERY GUY HERE, I FOUND SCHALPLAENE ON <a href="http://WWW.E28PLANET.COM">WWW.E28PLANET.COM</a>(UNDER THE BUTTON &quot;etms&quot; ....IF YOU NEED THEM...THERE IS ALSO THE WIRING DIAGRAMS FOR THE 524TD MODELS...)</p>
<p>FOR THIS MOMENT I THANK YOU ALL!<br />
REGAARDS FROM THE COLD OF NORTH ITALY<br />
(TODAY -5°C /4°C ... AND SOMEONE CALLS THIS&quot; THE COUNTRY OF THE SUN&quot;... )</p>
<link>http://e28-forum.lewonze.de/forum/index.php?id=115903</link>
<guid>http://e28-forum.lewonze.de/forum/index.php?id=115903</guid>
<pubDate>Fri, 13 Jan 2006 21:24:47 +0000</pubDate>
<category>Allgemein</category><dc:creator>Francesco aus Norditalien 1983 635 3,3LAutomatic</dc:creator>
