<title>E28-Forum - Re: 525i E28 -85 changing from L-jetronic to motronic</title>
<title>Re: 525i E28 -85 changing from L-jetronic to motronic (Antwort)</title>
Als Antwort auf: <strong>Re: 525i E28 -85 changing from L-jetronic to motronic</strong> von Luan am 18. Dezember 2002 22:42:50:</p>
<blockquote><blockquote><p>Sorry for writing in English, I'm from Finland so I don't know much German...</p>
</blockquote></blockquote><blockquote><p>hello,<br />
english is no problem<img src="http://e28-forum.lewonze.de/forum/images/smilies/wink.png" alt=";-)" />))<br />
is no big thing to change from LE-jetronic (this system is used in E 28)<br />
to motronic,as they are quite similar.<br />
all you need are the complete cable-bus from motronic, <br />
digital distributor from motronic (LE-jetronic got dynamic one)<br />
the special motronic flywheel with scaling for ignition point<br />
transmittor, the transmittor itself and a compatible gearbox (no problem as <br />
most ones are prepared yet).<br />
then you need the electronical components as there are air-mass-messuring-unit, <br />
motronic-box (the computer).<br />
depending on the generation of the used motronic you will also have or not to <br />
use a lambda-oxygen-sonde.<br />
thats it.</p>
</blockquote><p>That sounds quite easy. </p>
<p>The simpliest way is maybe using parts from M30B35 engine with motronic <br />
(E28 535i), most of it should fit without any corrections. Is that right?<br />
Btw, this version of motronic has still a mechanical distributor...</p>
<blockquote><p>the effect: motronic works much better, as ignition is digitally worked out and <br />
so the character will be smoother and softer, the injection part is (nearly) <br />
the same as jetronic, so this won't influence very much.<br />
and most times motronic equiped ones guzzle (consomme) less petrol.</p>
</blockquote><p>The chip inside of the electronic box should be designed especially<br />
for a particular engine, otherwise the advantage may not take effect.<br />
But the M30B25 engine was never fitted with motronic. Is there any<br />
source for chips?</p>
<p>N.</p>
<link>http://e28-forum.lewonze.de/forum/index.php?id=14336</link>
<guid>http://e28-forum.lewonze.de/forum/index.php?id=14336</guid>
<pubDate>Thu, 19 Dec 2002 08:34:21 +0000</pubDate>
<title>What about the different camshaft..? (Antwort)</title>
I think it's easier to change the whole engine and gearbox..</p>
<p>Jreetings</p>
<link>http://e28-forum.lewonze.de/forum/index.php?id=14333</link>
<guid>http://e28-forum.lewonze.de/forum/index.php?id=14333</guid>
<pubDate>Thu, 19 Dec 2002 07:07:31 +0000</pubDate>
<category>Allgemein</category><dc:creator>Dr.Benz</dc:creator>
Als Antwort auf: <strong>525i E28 -85 changing from L-jetronic to motronic?</strong> von Markus am 17. Dezember 2002 20:59:33:</p>
</blockquote><p>hello,<br />
english is no problem<img src="http://e28-forum.lewonze.de/forum/images/smilies/wink.png" alt=";-)" />))</p>
<p>is no big thing to change from LE-jetronic (this system is used in E 28)<br />
transmittor, the transmittor itself and a compatible gearbox (no problem as most ones are prepared yet).<br />
then you need the electronical components as there are air-mass-messuring-unit, motronic-box (the computer).<br />
depending on the generation of the used motronic you will also have or not to use a lambda-oxygen-sonde.</p>
<p>thats it.</p>
<p>the effect: motronic works much better, as ignition is digitally worked out and so the character will be smoother and softer, the injection part is (nearly) the same as jetronic, so this won't influence very much.<br />
<p>greetz from germany, alex</p>
<link>http://e28-forum.lewonze.de/forum/index.php?id=14330</link>
<guid>http://e28-forum.lewonze.de/forum/index.php?id=14330</guid>
<pubDate>Wed, 18 Dec 2002 21:42:50 +0000</pubDate>
<category>Allgemein</category><dc:creator>Luan</dc:creator>
<title>Re: 525i E28 -85 changing from L-jetronic to motronic? (Antwort)</title>
<blockquote><p>Sorry for writing in English, I'm from Finland so I don't know much German...<br />
My question is:<br />
Is there anyway you could change from L-jetronic to Motronic on a E28 525i -85? Would this increase the effect of the car at all?<br />
Can anybody give me some tips for it or pictures?<br />
Thankfull for a answer!<br />
Regards,<br />
Markus</p>
</blockquote><p>Hi Markus!</p>
<p>Sorry, but I am not good at speaking and writing English, but I try to explain to you my opinion on this case.<br />
In your case it`s easier to change the engine in return for an engine with 170 PS (Bosch-Motronic) from a E34 525i or E30 325i. As well as I know you can exchange the engine without big problems, but I don´t guarantee for it.</p>
<p>Holger</p>
<link>http://e28-forum.lewonze.de/forum/index.php?id=14325</link>
<guid>http://e28-forum.lewonze.de/forum/index.php?id=14325</guid>
<pubDate>Wed, 18 Dec 2002 18:11:10 +0000</pubDate>
<category>Allgemein</category><dc:creator>Holger</dc:creator>
<title>525i E28 -85 changing from L-jetronic to motronic?</title>
<content:encoded><![CDATA[<p>Sorry for writing in English, I'm from Finland so I don't know much German...</p>
<p>My question is:</p>
<p>Is there anyway you could change from L-jetronic to Motronic on a E28 525i -85? Would this increase the effect of the car at all?</p>
<p>Can anybody give me some tips for it or pictures?</p>
<p>Thankfull for a answer!</p>
<p>Regards,</p>
<p>Markus</p>
<link>http://e28-forum.lewonze.de/forum/index.php?id=14303</link>
<guid>http://e28-forum.lewonze.de/forum/index.php?id=14303</guid>
<pubDate>Tue, 17 Dec 2002 19:59:33 +0000</pubDate>
<category>Allgemein</category><dc:creator>Markus</dc:creator>
