Re: motorproblem (Allgemein)
karl, Thursday, 15.02.2001, 17:14 (vor 9345 Tagen) @ Andreas
Als Antwort auf: Re: motorproblem von Andreas am 14. Februar 2001 20:54:04:
Thanks for your reaction.I prove the cable and it was still intact.
Sorry, I wasn´t exact about it. I meant the cable which connects the motor to car mass. Not easy to find.
It appears only in the cold wintertime.
Winter means wet conditions and water makes electrical problems worse. I´d really check for a mass problem first, because it´s most probable the cause and the least expensive one.
Andreas
thanks for your help you guy's.It was fluidproblem in the ignition.
my little girl is spinning like it use to do.
