E32/E34 M30B30 engine on E28 (Allgemein)
RobertRO ('86 535i), Tuesday, 18.10.2005, 12:33 (vor 7705 Tagen)
Has anyone installed a 3.0l M30B30 engine (188HP) from an E32 or E34, on a E28 chassis?
I have this project in mind, in order to replace the M30B34 engine (185HP) on my E28 535i. The idea is to get lower fuel comsumption and place myself into a cheaper taxation range (tax for engines over 3.0l is prohibitive).
I have a couple of questions:
1. Is there any shop selling, or at least some drawings, for the adapter plates needed to fit an M30B30 (or M30B35) engine sources from an E34 / E32, onto a E28 subframe? As you probably know, the mounts of E34/E32 M30 engines are shifted forward, compared to the M30B34 engine block.
2. Anyone can post some feedback about the behaviour of M30B30 engine, compared to low-compression 8:1 M30B34 engine?
Any input is highly appreciated.
