Re: M5 e28 (Allgemein)
Als Antwort auf: M5 e28 von popi am 06. Dezember 2005 10:38:35:
Statistics
Through the Gears:
0-30mph 2.3
0-40mph 3.5
0-50mph 4.8
0-60mph 6.2
0-70mph 8.4
0-80mph 10.5
0-90mph 12.9
0-100mph 16.6
Standing ¼ Mile 14.6sec Terminal speed 95.7mph
Displacement 3453cc
Bore 93.4mm
Stroke 84.0mm
Compression Ratio 10.5:1
Max Power 286bhp @6500rpm
Max Torque 250lb ft @4500rpm
BHP Per litre 82.7
Fuel System Bosch Motronic electronic injection & engine management
Cylinders Cast Iron block, seven main bearings
Cylinder Head Light Alloy, DOHC, four valves per cylinder
Gearbox 5 Speed manual
Final drive ratio 3.7:1 (25% LSD)
Clutch Single dry plate
Front Suspension MacPherson struts, double links, coil springs & gas dampers, anti roll bar.
Rear Suspension Semi-trailing arms, control links, coil springs & gas dampers anti roll bar.
Brakes Ventilated discs all round, 11.8in front with four-pot callipers & 10.7in rear. Servo assisted.
Wheels & Tyres 220/55VR 390 Michelin TRX tyres on 165TR390 alloy wheels (Press Car)
Unladen weight 3153Ib
Wheelbase 103.3in
Turning circle 33ft
Fuel tank capacity 70 Litres/15.4 Galls
Only 2180 units were ever built, of which 1235 were imported to the US.
