problem with BMW sound system(english) (Allgemein)
Francesco aus Norditalien 1983 635 3,3LAutomatic, Monday, 09.01.2006, 17:00 (vor 7622 Tagen)
Hello!
I put on my car (1983 635) the 8 speakers system (BMW sound System) with a Becker 830 (mexico diversity with code, produced in 1986-7) ...but sound is not so good:untill an average amount of volume is really good(a big improvement from old 4 speakers), when I turn up more the volume the speakers start to "pop" and to make strage noise then , sometimes, the speakers cut out(only when I turn up volume too much...).The volume is not so "heavy"...I tried to by-pass amplifier and installed the 8 speakers directly to the radio, and I reached a louder output than with amplifier
I tested the amplifier and seems in good conditions , speakers are like new(I removed those speakers from a car with 35k kms, sound system but not the radio(!?!?)..It was a 1986 528i e28 owned by a 89 years old man..Anywaythe first speakers I got from a 635 were suspects ..).
A radio repair center told me that those systems need a radio with 2x 20 W max output, or the amplifier will become a " distorsions-maker", more than a amplifier...and over the time I can burn it.
Also a bad ground of power antenna could be a real problem.
My radio output is currently doing 2x25 max ....
Does someone has got experience on those systems?
I do not have idea of the possible causes....
Thank You so much !
Francesco from North italy
Re: problem with BMW sound system(english)
Nico Hoffmann, Monday, 09.01.2006, 18:24 (vor 7622 Tagen) @ Francesco aus Norditalien 1983 635 3,3LAutomatic
Als Antwort auf: problem with BMW sound system(english) von Francesco aus Norditalien 1983 635 3,3LAutomatic am 09. Januar 2006 17:00:55:
O.K., so we have:
1.) Your radio is o.k.
2.) the sound system amplifier is also o.k., at least it seems so.
3.) your speakers are o.k.
But all together makes problems.
What about the wiring? If you took the ampifier from a 86 E28, you should
have that one below with only one rectangular connector.
(Do you use the wiring from the 528i?)
<IMG src="http://www.e28-forum.de/technik/sound/sound-verst-1.jpg" alt="http://www.e28-forum.de/technik/sound/sound-verst-1.jpg[/link]
Lets have a better view at the connector, if you take the amplifier
and look at the connector, it should look like that:
<IMG src="http://www.e28-forum.de/technik/sound/verst-stecker.jpg" alt="http://www.e28-forum.de/technik/sound/verst-stecker.jpg[/link]
and at pin 18 it should have a brown-black wire.
As I put the sound system in my E28, I experienced that this wire must have
gound (*NOT* the "-" of the speakers plug at the radio...!), or the
amplifier makes strange noise.
It does not really matter if your radio outputs 20 or 25 Watts. Maybe you
can roast your amplifier or or speakers, if you drive your system with
full volume over some time, but you will be deaf than anyway.
Your power antenna should have a separate ground. IIRC the ground for
this amplifier is below the back seat.
Francesco aus Norditalien 1983 635 3,3LAutomatic, Monday, 09.01.2006, 18:47 (vor 7622 Tagen) @ Nico Hoffmann
Als Antwort auf: Re: problem with BMW sound system(english) von Nico Hoffmann am 09. Januar 2006 18:24:08:
I write in capital letters:
YES AND WHEN I CONNECT THE 8 SPEAKERS BYPASSING AMPLIFIER, SPEAKERS ARE GOOD,ONLY THE SOUND IS LOGICALLY NOT SO CLEAN..
I GOT ONE WITH A LOT OF PROBLEMS (NOISE ALL THE TIME...I DISCOVERED THAT SOME CIRCUIT WERE FAULTY)AND NOW I GOT A GOOD ONE(I TESTED IT ON ONE M635)
YES...I TESTED THOSE SPEAKERS IN THE M635 I TOLD YOU
WIRING PLUG IS THE SAME AS THE AMPLIFIER IN THE LOW SIDE OF THIS PICTURE.
OK...
HUH?i TRY THIS EVENING AS SOON AS POSSIBLE AND TOMORROW I KEEP YOU INFORMED!!!!!
yES, AND IS ON GOOD CONDITIONS...
THANK YOU SO MUCH!!!!
TONIGHT I WILL INVESTIGATE AND I KEEP YOU INFORMED
GRUSSE, FRANCESCO
Francesco aus Norditalien 1983 635 3,3LAutomatic, Tuesday, 10.01.2006, 11:51 (vor 7621 Tagen) @ Francesco aus Norditalien 1983 635 3,3LAutomatic
Als Antwort auf: Re: problem with BMW sound system(english) von Francesco aus Norditalien 1983 635 3,3LAutomatic am 09. Januar 2006 18:47:59:
I tried to put the blackbrown wire to the ground , then I checked the brown wire for soundsystem wiring and it 's still the same, more or less...
Any other ideas?
Thank you so much for the moment,I hope to exchange the favour soon!
Re: High Francesco!
FJB, Tuesday, 10.01.2006, 16:29 (vor 7621 Tagen) @ Francesco aus Norditalien 1983 635 3,3LAutomatic
Als Antwort auf: Re: problem with BMW sound system(english) von Francesco aus Norditalien 1983 635 3,3LAutomatic am 10. Januar 2006 11:51:23:
Haven't heard anything from u 4 a long time!
Just had the intention of writing something to the Euro-E3 list.
E.g., that the engine of my second E3, a polaris 3.0 S automatic, started running unexpectedly last autumn (I had thougt it was dead because of drowning in Upper Autrian flood water in 2002).
Cheers, FJB.
Re: High Francesco!
Francesco aus Norditalien 1983 635 3,3LAutomatic, Wednesday, 11.01.2006, 10:38 (vor 7620 Tagen) @ FJB
Als Antwort auf: Re: High Francesco! von FJB am 10. Januar 2006 16:29:30:
So do I!!!!How are You!
I am fine ,thanks a lot!
I have intention to send You a long email, about the involvements of my cars and about old BMWs in Italy.
I'm pleased You have a second BMW(I didn't know) and also it's working again!
My 3,3L needs only a2-3 trims and again a ZF automatic gearbox.Then it will be back on the road again and we can meet !
THANK YOU SO MUCH!!!!!
Francesco
Cheers, FJB.
Klaus, Monday, 09.01.2006, 21:24 (vor 7622 Tagen) @ Francesco aus Norditalien 1983 635 3,3LAutomatic
Hello Francesco!
Salute and a happy new year - Many regards Klaus
THANK YOU KLAUS!HAPPY NEW YEAR to you , too
Francesco aus Norditalien 1983 635 3,3LAutomatic, Tuesday, 10.01.2006, 09:36 (vor 7621 Tagen) @ Klaus
Als Antwort auf: Re: problem with BMW sound system(english) von Klaus am 09. Januar 2006 21:24:58:
Ands also happy new year to all members of this forum!
