soundsystem problems...Part number 2 (english) (Allgemein)
Francesco aus Norditalien 1983 635 3,3LAutomatic, Friday, 13.01.2006, 22:24 (vor 7617 Tagen)
Hello!
After the first part of the saga, i received a lot of info and sugestions from You. And I'd like to thank you. But the problem is still there.
I give 1 answer to Nico, that seems to have a lot of experence with this stuff.
I wrote below what he asked me (I WRITE IN CAPITAL LETTERS , SO YOU UNDERSTAND WHAT IS MY ANSWER)
O.K., so we have:
1.) Your radio is o.k. (SERVICED RECENTLY FROM BECKER OF MUNICH, THANK S TO MY FRIEND WHO HAS HIS MUM LIVING THERE)
2.) the sound system amplifier is also o.k., at least it seems so.
IT SEEMS GOOD,OTHERWISE I PURCHASED 2 BAD AMPLIFIER ON EBAY...CAN I TEST THE AMPLIFIER IN SOME WAY? I TRIED THE LAST ONE IN THE CAR OF MY FRIEND , A 1985 M635 CSI, AND WORKED GOOD).
3.) your speakers are o.k. (YESSSSSSS...)
But all together makes problems. (YEP.... :-( )
What about the wiring? If you took the ampifier from a 86 E28, you should
have that one below with only one rectangular connector.
YES RECTANGULAR CONNECTOR
(Do you use the wiring from the 528i?)
WIRING LOOM WAS TAKENFROM A E30...WITH THE RIGHT WAY UNDER THE FLOOR, WIRES ARE LONG ENOUGH...HUH, THEY WERE NEW, SO I BELEIVE IT'S IN GOOD CONDITIONS)
and at pin 18 it should have a brown-black wire.
As I put the sound system in my E28, I experienced that this wire must have
gound (*NOT* the "-" of the speakers plug at the radio...!), or the
amplifier makes strange noise.
I TRIED TO PUT A JUMPER WIRE FROM THE PIN 18 TO THE GROUND ...IT MAKES NOT DIFFERENCE
It does not really matter if your radio outputs 20 or 25 Watts.
I WAS TOLD THAT A RADIO WITH LESS POWER ENABLE THE AMPLIFIER TO MAKE LESS DISTORSIONS OF THE SOUND....
Maybe you
can roast your amplifier or or speakers, if you drive your system with
full volume over some time, but you will be deaf than anyway.
Your power antenna should have a separate ground. IIRC the ground for
this amplifier is below the back seat.
I TRIED THE GROUND AND IT'S GOOD......BUT I HAVE OTHER BROWN WIRES IN THAT GROUND CONNECTIONS...MAYBE I HAVE TO TRY TO BOLT GROUND ON A "EXCLUSIVE " GROUND POINT).
THE ANTENNA IS A BOSCH AUTOJET 2 , IN WORKING ORDER....I DON'T THINK IT IS THE CULPRIT BUT I CAN TRY WITH A HIRSCHMANN AUTA 6000 . I BOUGHT IT FROM EBAY(LIKE NEW) , WHEN IT ARRIVES AT HOME i CAN CHANGE IT AND CHECK IT FOR THIS PROBLEM.
FOR EVERY GUY HERE, I FOUND SCHALPLAENE ON WWW.E28PLANET.COM(UNDER THE BUTTON "etms" ....IF YOU NEED THEM...THERE IS ALSO THE WIRING DIAGRAMS FOR THE 524TD MODELS...)
FOR THIS MOMENT I THANK YOU ALL!
REGAARDS FROM THE COLD OF NORTH ITALY
(TODAY -5°C /4°C ... AND SOMEONE CALLS THIS" THE COUNTRY OF THE SUN"... )
