Re: Front and rear adjustable wheel alignment (Allgemein)
Rat Baron, Sunday, 13.08.2006, 22:04 (vor 7397 Tagen) @ RobertRO
Als Antwort auf: Front and rear adjustable wheel alignment von RobertRO am 12. August 2006 07:27:17:
Hi there,
im sorry noone replied til now, well I dont know, but why is your camber so far off? Sounds like you hit a curb or suffered some major accident?
Adjustable strut mounts are not very common over here, I think they arent even street legal. But any decent bodywork shop should be able to get your strut turret back to spec, I think that should be easier than messing around with adjustable mounts, give it a shot, ask some body work guy around where you live.
If you have a 2nd wrecker e28 or a wreckyard nearby, might be easier to swap the whole rear axle than fixing the toe-in problem, but I cant really recommend "adjustable" bushings... Sounds too much like fighting the symptoms and not the problem itself to me...
Greets,
Simon
In order to bring back on factory specs the front right wheel camber and the rear right wheel toe on my E28, I have to install adjustable front strut mounts and rear trailing arm bushings.
The only products with good references I found so far are manufactured by a company called KMac, from Australia:
http://www.k-mac.com/makes/bmw.htm
Has anyone on this forum installed them? Would you recommend them?
I wonder if there are similar products / solutions from a German / European company.
Thanks.
