525i E28 -85 changing from L-jetronic to motronic? (Allgemein)
Markus, Tuesday, 17.12.2002, 20:59 (vor 8684 Tagen)
Sorry for writing in English, I'm from Finland so I don't know much German...
My question is:
Is there anyway you could change from L-jetronic to Motronic on a E28 525i -85? Would this increase the effect of the car at all?
Can anybody give me some tips for it or pictures?
Thankfull for a answer!
Regards,
Markus
Re: 525i E28 -85 changing from L-jetronic to motronic?
Holger, Wednesday, 18.12.2002, 19:11 (vor 8683 Tagen) @ Markus
Als Antwort auf: 525i E28 -85 changing from L-jetronic to motronic? von Markus am 17. Dezember 2002 20:59:33:
My question is:
Regards,
Markus
Hi Markus!
Sorry, but I am not good at speaking and writing English, but I try to explain to you my opinion on this case.
In your case it`s easier to change the engine in return for an engine with 170 PS (Bosch-Motronic) from a E34 525i or E30 325i. As well as I know you can exchange the engine without big problems, but I don´t guarantee for it.
Holger
Luan, Wednesday, 18.12.2002, 22:42 (vor 8683 Tagen) @ Markus
hello,
english is no problem;-)))
is no big thing to change from LE-jetronic (this system is used in E 28)
to motronic,as they are quite similar.
all you need are the complete cable-bus from motronic,
digital distributor from motronic (LE-jetronic got dynamic one)
the special motronic flywheel with scaling for ignition point
transmittor, the transmittor itself and a compatible gearbox (no problem as most ones are prepared yet).
then you need the electronical components as there are air-mass-messuring-unit, motronic-box (the computer).
depending on the generation of the used motronic you will also have or not to use a lambda-oxygen-sonde.
thats it.
the effect: motronic works much better, as ignition is digitally worked out and so the character will be smoother and softer, the injection part is (nearly) the same as jetronic, so this won't influence very much.
and most times motronic equiped ones guzzle (consomme) less petrol.
greetz from germany, alex
What about the different camshaft..?
Dr.Benz, Thursday, 19.12.2002, 08:07 (vor 8682 Tagen) @ Luan
Als Antwort auf: Re: 525i E28 -85 changing from L-jetronic to motronic von Luan am 18. Dezember 2002 22:42:50:
I think it's easier to change the whole engine and gearbox..
Jreetings
Nico Hoffmann, Thursday, 19.12.2002, 09:34 (vor 8682 Tagen) @ Luan
hello,
thats it.
That sounds quite easy.
The simpliest way is maybe using parts from M30B35 engine with motronic
(E28 535i), most of it should fit without any corrections. Is that right?
Btw, this version of motronic has still a mechanical distributor...
The chip inside of the electronic box should be designed especially
for a particular engine, otherwise the advantage may not take effect.
But the M30B25 engine was never fitted with motronic. Is there any
source for chips?
