schaltwegverkürzung (Allgemein)
<center>http://www.unofficialbmw.com/images/z43-0.jpg</center>
schön gemachtes foto aus dem ami forum..
hier der text:
But if budget limited:
These will mount in the e28 both the sheetmetal, early up to 87, and the exttruded aluminum shifting plates, after 87.
This is a DIY project for most e28 owners.
The Z3 has a slight bend and is more ergonomically correct. It puts the knob a little aft of the others.
Distance from the pivot to the lower rod bearing point is the major change in shortening the shift distance. Remember any change in length is increasing the needed force.
