Re: excessive trailer-hunting at 55mph (Allgemein)
Kai R., Monday, 30.10.2006, 14:21 (vor 7318 Tagen) @ Ken Worth
Als Antwort auf: excessive trailer-hunting at 55mph von Ken Worth am 29. Oktober 2006 22:09:03:
Hi Fellows,
i often pull a trailer on my M535i to carry my mudracer to and
from the track,
unfortunately i have severe trailer hunting problems at 55mph. No matter how i
changed the position of the cargo on the trailer on my last run to Western
Kentucky it never did run as smooth than behind my fathers
yellow Siverado.
Other people say that such kind of compact car isn´t suitable to pull a
under loaded 4000lbs trailer. How about your experience of pulling with an e28?
Kind Regards,
Ken
it cannot run as smoothly as behind a 6000lbs silverado. Its simply a question of the weight of the towing veihicle. However it should be doing okay cruising at 55, eben behind an M535. Is the trailer all right, especially the tire pressure? Are the shocks of you BMW equally okay?
You can weigh the weight on your tow-hook. The right weight to press on the hook should be shown somewhere near the hook. If that is correct, the towing should be working fine.
Regards,
Kai
