Re: Korrektur... (Allgemein)
Derin, Thursday, 19.07.2007, 23:14 (vor 7027 Tagen) @ Matze
Als Antwort auf: Re: Korrektur... von Matze am 19. Juli 2007 23:01:18:
You can put E38 wheels on an E28 or E34 5-Series...no problem. You can even out put E39 wheels on an E34 if you use hubcentric rings with them...but you can't so it the other way!
But the "ET23" of the 8x16 is something closely on E28 (front axle), or not?
Yes, I think they were close Matze...but I had no rubbing or fouling of the wheels on anything at all. You can also use (instead of 205/55/16 tyres) 225/50/16...I think (!) but I need to double-check with a friend of mine who used the same wheels but with this tyre size on an M535i.
It worked well and looked nice on that car too because the wider and lower profile tyres suited the more 'sporty' style of the M535i.
Both tyre sizes keep the rolling circumference of the tyres VERY close to original TRX and so no problem with gearing.
Thanks,
Derin
http://www.bmwclassics.co.uk
