Low ZDDP in modern oils may be an issue for BMW M30 engines
RobertRO, Wednesday, 12.03.2008, 10:32 (vor 6834 Tagen)
I think that most of you know already about a possible valvetrain wear problem, that may occur when using modern (API SL/SM rated) oils in older engines, like BMW M30 or M20, due to low zinc-dialkyl-dithio-phosphate levels in the oil.
For example, please check the links below:
Link to a discussion topic on mye28.com board
Mobil Oil statement about ZDDP levels in their oils
My question is, what kind/brand of oil do you use in Germany in your BMW M30 / M20 engines, to avoid this problem?
