After a heavy rain and deep water - engine problems... (Allgemein)
Robert RO (1986 E28 535i ), Friday, 25.07.2003, 13:09 (vor 8470 Tagen)
Dear friends,
I think I screwed it this time.
Yesterday it rained VERY heavy in my area. The city's obsolete sewerage system couldn't handle it, so there was a 2..3 cm high film of water covering most of the streets.
The problem is that I noticed too late that I drove into a lower street area, and all of a sudden have found myslef in deeper water, about as high as to the center of the wheels. (Yes, I know, stupid me).
The water trap was about 100m long.
I drove slowly out of it, but immediately after that a problem developed: the engine has a serious hesitation between 1800 rpm and 3000 rpm. It simpky doesn't want to pull, as if there isn't enough gas, or spark.
Otherwise, it idles fine, and pulls strong above 3000 rpm. Full throttle and no throttle is all right, but light throttle is a nightmare.
I waited one day hoping that it will eventually dry out and pass over it. Well, it didn't.
I would highly appreciate any suggestions about the probable culprit.
Please note that, although I have the 185HP engine, I run it without cat and O2 sonde.
http://www.geocities.com/robert_sgi/
Re: After a heavy rain and deep water - engine problems...
Jochen, Saturday, 26.07.2003, 17:17 (vor 8468 Tagen) @ Robert RO (1986 E28 535i )
Als Antwort auf: After a heavy rain and deep water - engine problems... von Robert RO (1986 E28 535i ) am 25. Juli 2003 13:09:50:
Hi Rob,
If you get some water in your Ignitionsystem,is there only one solution.You have to screw down your Ignitioncap(?) and dry it.There is no air-change inside,thats the reason why it needs a very long time for drying.
I hope I could help you.
I solved it out
Robert RO (1986 E28 535i, Sunday, 27.07.2003, 14:21 (vor 8467 Tagen) @ Jochen
Als Antwort auf: Re: After a heavy rain and deep water - engine problems... von Jochen am 26. Juli 2003 17:17:28:
Thanks for your reply.
I have found the culprit. It was an oxidized contact at the large Motronic connector. Unbelivable. When I drove through the water, a lot of steam came in the pessenger compartiment through the vent holes. Removing and then replugging the cable connector to the Motronic unit solve it out.
Hi Rob,
