Re: Outside temp sensor wire location (Allgemein)
Nico Hoffmann, Wednesday, 03.03.2004, 16:23 (vor 8256 Tagen) @ YogiE28
Als Antwort auf: Outside temp sensor wire location von YogiE28 am 03. März 2004 15:53:48:
<center>http://www.e28-forum.de/bilder/mix/e28-temp-durchbruch.jpg</center>
Can someone here tell me the exact location of where the wire to the outside temp
sensor of the BC goes through the firewall? There are several locations where
this could be done but I want to know the original location.
Look at the picture. On the right you see the clutch pedal, upper left the
multi purpose connector. The blue wire with the black connector and the black
coating is your friend...
(The black piece of rubber is already in your E28.)
Also, am I correct that the wire runs across the inside of the left fender?
Someone who has taken an E28 apart for parts should know this.
Correct. It takes the same way like all the other wires.
