Re: klemm die Batterie für 5 min ab... (Allgemein)
YogiE28, Monday, 24.05.2004, 23:31 (vor 8179 Tagen) @ Daniel Göppel
Als Antwort auf: Re: klemm die Batterie für 5 min ab... von Daniel Göppel am 23. Mai 2004 22:29:21:
Hab ich heute ausprobiert, hat aber leider nicht funtioniert. Trotzdem mal danke, weitere Vorschläge sind natürlich immer gerne willkommmen.
Showing PPPP happens most of the time after you jump started the car or with any other thing that causes spikes in the voltage supply. The BC is sensitive to that, and shows PPPP if programming is lost. First, visit this website:
http://home.att.net/~ebaines/e28_obc.htm
And follow the instructions on how to reset the BC if it reads PPPP. If that doesn't help, disconnect the green connector at the back of the BC and leave it off for about 24 hours and try again. If that doesn't help either, the code plug in the back of the BC, or the BC unit itself is faulty and should be replaced.
Good luck, and please excuse me for not writing in German <img src=http://bilder.parsimony.net/smilies/zwinker.gif alt=zwinker>
