@ Fabs (Allgemein)
YogiE28, Tuesday, 19.10.2004, 16:17 (vor 8045 Tagen)
Hello Fabs.
I've found the info about how to connect the intensive wash system to the existing windshield washers. The EBA is for the E30 series, but the diagram for the hoses and valves under the hood should be identical for the E28. Part numbers for the valves should be in the E30 ETK.
Here is the link:
http://www.m535i.org/e28info/headlightwiwa/EBADoc33906_E30headlight_IntWiWa.pdf
I hope the info is useful to you.
Re: @ Fabs
Fabs, Tuesday, 19.10.2004, 21:52 (vor 8045 Tagen) @ YogiE28
Als Antwort auf: @ Fabs von YogiE28 am 19. Oktober 2004 16:17:14:
Hello Fabs.
Here is the link:
Hi YogiE28,
i really wonder about the diagram for the hoses. This works?
The E28series wich "gave" me the washer-kit was wired like i did it.
Because the valve was not in function, i tried to connect it like the way in the EBA. But it do not work. The washer water was pressed out of the little holes in the valves.
May be the valves and the diagram is different. But when it works... no problem.
Sorry, about my bad english. I must only understand in my job, not write or speak...
In spite of all: Thanks.
Regards
Re: @ Fabs
YogiE28, Wednesday, 20.10.2004, 00:59 (vor 8045 Tagen) @ Fabs
Als Antwort auf: Re: @ Fabs von Fabs am 19. Oktober 2004 21:52:14:
Hi Fabs.
I have a written description from someone with a 7-series. The way the valves are hooked up is the same for E30, E28, E24 etc. His system is factory fitted, and it is different from the way you connected it.
If you're interested, you can e-mail me, it's quite a long description. I think you'll find it useful to get your system working. Just want to help a fellow enthusiast.
By the way, there's nothing wrong with your English. My German is far worse, that's why I always post this way! <img src=http://bilder.parsimony.net/smilies/zwinker.gif alt=zwinker>
Re: @ Fabs
Fabs, Thursday, 21.10.2004, 01:08 (vor 8044 Tagen) @ YogiE28
Als Antwort auf: Re: @ Fabs von YogiE28 am 20. Oktober 2004 00:59:03:
Well, my sytem works. If the "phantom" valve without partnumber needed to be replaced, i come back to your offer immediatly :-)
But your information can be useful for other e28-drivers, maybe Nico can make it public. If webspace is a problem.... i've more than i could't use... :-)
Thanks, for the flowers.
Correction :-)
Fabs, Thursday, 21.10.2004, 01:10 (vor 8044 Tagen) @ Fabs
Als Antwort auf: Re: @ Fabs von Fabs am 21. Oktober 2004 01:08:24:
"...more than i could't use... :-)"
means
"...more than i could use... :-)"
Ok Fabs ;-) (kwt)
YogiE28, Thursday, 21.10.2004, 01:22 (vor 8044 Tagen) @ Fabs
Als Antwort auf: Correction :-) von Fabs am 21. Oktober 2004 01:10:39:
