Re: @ Fabs (Allgemein)
Fabs, Tuesday, 19.10.2004, 21:52 (vor 8045 Tagen) @ YogiE28
Als Antwort auf: @ Fabs von YogiE28 am 19. Oktober 2004 16:17:14:
Hello Fabs.
I've found the info about how to connect the intensive wash system to the existing windshield washers. The EBA is for the E30 series, but the diagram for the hoses and valves under the hood should be identical for the E28. Part numbers for the valves should be in the E30 ETK.
Here is the link:
http://www.m535i.org/e28info/headlightwiwa/EBADoc33906_E30headlight_IntWiWa.pdf
I hope the info is useful to you.
Hi YogiE28,
i really wonder about the diagram for the hoses. This works?
The E28series wich "gave" me the washer-kit was wired like i did it.
Because the valve was not in function, i tried to connect it like the way in the EBA. But it do not work. The washer water was pressed out of the little holes in the valves.
May be the valves and the diagram is different. But when it works... no problem.
Sorry, about my bad english. I must only understand in my job, not write or speak...
In spite of all: Thanks.
Regards
