Re: Irgendwo gibt es da aber auch noch eine richtige M30-Site, (Allgemein)
Als Antwort auf: Re: There is a hell of an informative M30-page where you can excerpt all those von FJB am 28. April 2005 12:36:09:
die ich aber jetzt nicht mehr gefunden habe.
FJ.
I have decided to convert the enigine of my '86 E28 535i, form 8:1 compression to 10:1 compression. I have the pistons, the 061 Motronic ECU and the 264 degrees camshaft. Of course, plus the usual stuff (gaskets and so on) needed for such an operation.
The question is if I should use the original M30B34 cylinder head, or maybe I should go for the M30B35 (E32 735i or E34 535i) head (+related intake manifold).
The M30B35 head has larger intake valves and flows better. So t should provide better performance. On the other hand, the compression chambers are larger, thus the compression ratio, with M30B34 pistons, would be around 9.5:1, compared to 10:1 with original M30B34 head.
What would you suggest? Should I stick with the original BMW design, or go for an experiment? (note that I don't have the M30B35 pistons, and they are different than M30B34 10:1 pistons).
Other (collateral) question: I understood that it is possible to install the M88/S38 M5 intake manifold (with individual throttle plates per cylinder) on an M30 head. Probably that would require a special adapter. Has anyone done this before? Any references, maybe pictures?
Thank you in advance.
