Re: Manual sunroof to electric? (Allgemein)
Als Antwort auf: Manual sunroof to electric? von YogiE28 am 16. Februar 2004 03:19:48:
The conversion from manual to electric sunroof schould not be too difficult. You have to change the mounting plate, then you can bolt on the motor/transmission-unit. For a better look you also change the front headlining cover. I'm not shure you've got the powersupplywire for the motor, possibly you have to install the wires.
Part numbers:
mounting plate for electric control ******** 54 12 1 860 187
electric sliding-lifting roof transmission ** 54 12 1 874 871
micro switch ******************************** 61 13 1 377 134
front headlining cover (anthrazit) ********** 51 44 1 873 479
cover for sliding roof motor (anthrazit)***** 51 44 1 864 536
emergency tool for sliding roof ************ 54 12 1 873 572
part numbers are for information only, please check the part numbers before ordering the parts.
Chris
