Re: Dirt on rear end (Allgemein)
Als Antwort auf: Dirt on rear end von YogiE28 am 14. März 2004 19:15:05:
Hello.
On the rear end of my Alpinweiss 525i there's always kind of a brown/yellow "versmutzung". If I'm correct this is caused from "dirty" exhaust gasses, cars with cat don't seem to have this trouble. It's pretty stubborn stuff and can only be removed by polishing, but it always returns after some time. It's looks dirty, and all that polishing all the time isn't good either....
What can be done about this? Will a chrome exhaust tip help maybe?
Thanks.
I think the dirt on rear end is a result of burned oil. Does your engine take oil? In this case, it is most likely that you have to repair the fittings (Dichtung) of your valves.
Kind regards
Nic
