Re: Dirt on rear end (Allgemein)
YogiE28, Monday, 15.03.2004, 15:14 (vor 8245 Tagen) @ Nick
Als Antwort auf: Re: Dirt on rear end von Nick am 15. März 2004 11:07:02:
Hi Nic, thanks for your reply.
No, it doesn't burn oil at all. Between oil services there's not even a need to top it off, the marking on the dipstick stays where it's at. It doesn't smoke on starting or deceleration either. I was thinking of this myself, but it isn't what causes this. Ah well....
Thanks again.
I think the dirt on rear end is a result of burned oil. Does your engine take oil? In this case, it is most likely that you have to repair the fittings (Dichtung) of your valves.
Kind regards
Nic
