Re: Codierstecker BC2 / Einstellpoti? (Allgemein)
Als Antwort auf: Re: Codierstecker BC2 / Einstellpoti? von YogiE28 am 28. März 2004 03:20:45:
Hallo Marco.
The code plugs are all white and thus not color coded. At the back of the plug you see 5 5 TYP, this is the software type of the plug, under that you should see the numbers 1 375 818 (these are the last seven digits of the part number, which is 65 81 1 375 818). The plugs for the 525i, 528i, 535i and M535i are the same, so if the plug has this number, which it should if it came out of a 535i, you can use it. The 518, 520 and Eta models use different plugs with other numbers.
The main BC cable is about 50 Euro, the temp sensor cable about 15 Euro and the temperature sensor about 40 Euro at the dealer.
Sorry for my answer in English, but I'm terrible at writing in German, I hope you'll understand but if not maybe Nico can translate it for you.
Good luck.
Hallo zusammen,
wie kann ich eigentlich die unterschiedlichen Codierstecker auf dem BC unterscheiden? Geht das nach Farbe? Meiner ist weiss..ich hoffe das passt, da der BC angeblich aus nem 535er stammt..
Dann ist auf der Rückseite ein Einstellpoti (?) mit den stellungen CH30, 30 und 60. Was ist das? Im moment steht es auf 30...
Danke für die Antworten....
Hello Yogi,
many thanks for your useful answer! I cant check the numbers right now, as I dont have the BC at hand.
Hmm regarding the cables - i think i will wait a little longer, maybe i have luck and they appear on ebay in the next future
Thanks and have a nice Weekend,
