Depends on the Motronic (Allgemein)
Als Antwort auf: Octane value for gasoline: M30B34 with 10:1 compression von RobertRO ('86 535i) am 01. September 2005 14:13:37:
95 Octane is normally enough for 10,1 compression, but the Motronic is programmed for 98 Octane. Try to change the "steering"(?) times.
Greetz, Christian
What is the minimum octane value of the gasoline that can be used with the high-compression 10:1 M30B34 engine of E28 535i, to avoid any risk of pinging / detonation?
Is it 95 octane enough? Or one must use 98 octane gasoline?
Thanks.
