Re: Depends on the Motronic (Allgemein)
Als Antwort auf: Depends on the Motronic von ChrisAS am 01. September 2005 23:45:54:
<font color="990000[/link]<b>Hi Chris,</b></font>
95 Octane is normally enough for 10,1 compression, but the Motronic is programmed for 98 Octane.
Try to change the "steering"(?) times.
<font color="990000[/link]<b>bytheway - how do you change them exactly ? ;-D
</b></font>
Greetz, Christian
What is the minimum octane value of the gasoline that can be used with the high-compression 10:1 M30B34 engine of E28 535i, to avoid any risk of pinging / detonation?
Is it 95 octane enough? Or one must use 98 octane gasoline?
<font color="990000[/link]<b>I'd rather consult the manual instead of risking severe damage.
Surely every authorized BMW-dealer should be able to answer this question.</b></font>
Thanks.
<font color="990000[/link]<b>can you post some pictures of your car ?
yours
Frajo</b></font>
