problem with BMW sound system(english) (Allgemein)
Hello!
I put on my car (1983 635) the 8 speakers system (BMW sound System) with a Becker 830 (mexico diversity with code, produced in 1986-7) ...but sound is not so good:untill an average amount of volume is really good(a big improvement from old 4 speakers), when I turn up more the volume the speakers start to "pop" and to make strage noise then , sometimes, the speakers cut out(only when I turn up volume too much...).The volume is not so "heavy"...I tried to by-pass amplifier and installed the 8 speakers directly to the radio, and I reached a louder output than with amplifier
I tested the amplifier and seems in good conditions , speakers are like new(I removed those speakers from a car with 35k kms, sound system but not the radio(!?!?)..It was a 1986 528i e28 owned by a 89 years old man..Anywaythe first speakers I got from a 635 were suspects ..).
A radio repair center told me that those systems need a radio with 2x 20 W max output, or the amplifier will become a " distorsions-maker", more than a amplifier...and over the time I can burn it.
Also a bad ground of power antenna could be a real problem.
My radio output is currently doing 2x25 max ....
Does someone has got experience on those systems?
I do not have idea of the possible causes....
Thank You so much !
Francesco from North italy
