Re: problem with BMW sound system(english) (Allgemein)
Francesco aus Norditalien 1983 635 3,3LAutomatic, Monday, 09.01.2006, 18:47 (vor 7622 Tagen) @ Nico Hoffmann
Als Antwort auf: Re: problem with BMW sound system(english) von Nico Hoffmann am 09. Januar 2006 18:24:08:
I write in capital letters:
1.) Your radio is o.k.
YES AND WHEN I CONNECT THE 8 SPEAKERS BYPASSING AMPLIFIER, SPEAKERS ARE GOOD,ONLY THE SOUND IS LOGICALLY NOT SO CLEAN..
2.) the sound system amplifier is also o.k., at least it seems so.
I GOT ONE WITH A LOT OF PROBLEMS (NOISE ALL THE TIME...I DISCOVERED THAT SOME CIRCUIT WERE FAULTY)AND NOW I GOT A GOOD ONE(I TESTED IT ON ONE M635)
3.) your speakers are o.k.
YES...I TESTED THOSE SPEAKERS IN THE M635 I TOLD YOU
But all together makes problems.
What about the wiring? If you took the ampifier from a 86 E28, you should
have that one below with only one rectangular connector.
(Do you use the wiring from the 528i?)
WIRING PLUG IS THE SAME AS THE AMPLIFIER IN THE LOW SIDE OF THIS PICTURE.
and at pin 18 it should have a brown-black wire.
OK...
As I put the sound system in my E28, I experienced that this wire must have
gound (*NOT* the "-" of the speakers plug at the radio...!), or the
amplifier makes strange noise.
HUH?i TRY THIS EVENING AS SOON AS POSSIBLE AND TOMORROW I KEEP YOU INFORMED!!!!!
It does not really matter if your radio outputs 20 or 25 Watts. Maybe you
can roast your amplifier or or speakers, if you drive your system with
full volume over some time, but you will be deaf than anyway.
Your power antenna should have a separate ground. IIRC the ground for
this amplifier is below the back seat.
yES, AND IS ON GOOD CONDITIONS...
THANK YOU SO MUCH!!!!
TONIGHT I WILL INVESTIGATE AND I KEEP YOU INFORMED
GRUSSE, FRANCESCO
