Re: problem with BMW sound system(english) (Allgemein)
Als Antwort auf: problem with BMW sound system(english) von Francesco aus Norditalien 1983 635 3,3LAutomatic am 09. Januar 2006 17:00:55:
I put on my car (1983 635) the 8 speakers system (BMW sound System) with a
Becker 830 (mexico diversity with code, produced in 1986-7) ...but sound is not
so good:untill an average amount of volume is really good(a big improvement
from old 4 speakers), when I turn up more the volume the speakers start to
"pop" and to make strage noise then , sometimes, the speakers cut out(only when
I turn up volume too much...).The volume is not so "heavy"...I tried to by-pass
amplifier and installed the 8 speakers directly to the radio, and I reached a
louder output than with amplifier
I tested the amplifier and seems in good conditions , speakers are like new(I
removed those speakers from a car with 35k kms, sound system but not the
radio(!?!?)..It was a 1986 528i e28 owned by a 89 years old man..Anywaythe
first speakers I got from a 635 were suspects ..).
A radio repair center told me that those systems need a radio with 2x 20 W max
output, or the amplifier will become a " distorsions-maker", more than a
amplifier...and over the time I can burn it.
Also a bad ground of power antenna could be a real problem.
My radio output is currently doing 2x25 max ....
O.K., so we have:
1.) Your radio is o.k.
2.) the sound system amplifier is also o.k., at least it seems so.
3.) your speakers are o.k.
But all together makes problems.
What about the wiring? If you took the ampifier from a 86 E28, you should
have that one below with only one rectangular connector.
(Do you use the wiring from the 528i?)
<IMG src="http://www.e28-forum.de/technik/sound/sound-verst-1.jpg" alt="http://www.e28-forum.de/technik/sound/sound-verst-1.jpg[/link]
Lets have a better view at the connector, if you take the amplifier
and look at the connector, it should look like that:
<IMG src="http://www.e28-forum.de/technik/sound/verst-stecker.jpg" alt="http://www.e28-forum.de/technik/sound/verst-stecker.jpg[/link]
and at pin 18 it should have a brown-black wire.
As I put the sound system in my E28, I experienced that this wire must have
gound (*NOT* the "-" of the speakers plug at the radio...!), or the
amplifier makes strange noise.
It does not really matter if your radio outputs 20 or 25 Watts. Maybe you
can roast your amplifier or or speakers, if you drive your system with
full volume over some time, but you will be deaf than anyway.
Your power antenna should have a separate ground. IIRC the ground for
this amplifier is below the back seat.
